I have just install the StarWInd iSCSI Iniator.
Whenever I launch it and try to add to a remote target the product hangs and there is no way to kill it.
The windows task manager Applications pane shows: "StarWind iSCSI Initiator" not responding
The windows task manager Processes pane shows: "StarISCSI.exe *32"
I tried to end process, process tree but nothing works.
I first ran with Microsoft default iSCSI initiator still runing but I've since removed that, disabled the Microsoft iSCSI initiator Service and the Microsoft iSCSI Device. I've rebooted between tests and it doesn't matter what I do. The StarWind initiator just hangs every time I run it.
The log file is full of thousands and thousands of lines like:
6/26 18:09:56.265 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/26 18:09:56.671 >> CMainFrame::CheckForEventMessage()
6/26 18:09:56.671 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/26 18:09:57.077 >> CMainFrame::CheckForEventMessage()
6/26 18:09:57.077 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
I really want to use this initiator as I believe the Microsoft one keeps bluescreen crashing my PC when I use BusTrace application.
If this StarWind initiator is not supported any longer or is known defective just let me know.
Thank you.
-Tim
