Tim
Thu Jun 06, 2013 11:40 am
Only reason I ask is because in some cases the MS iSCSI Init is a bit buggy so I use your one instead.
For example: If I use Starwind to make a BlueRay optical drive available for remote use, the MS iSCSI software/driver will cause a BSOD x012E on the remote machine when trying to use the drive.
Your iSCSI Initiator works fine (as I would expect because you guys know your stuff).
Tim
(Sorry of this is the wrong forum section, wasn't sure where to put this)
Thu Jun 06, 2013 3:03 pm
No. It's in legacy state and we have plans to drop it completely soon. You know the reason..........................
Tim wrote:Only reason I ask is because in some cases the MS iSCSI Init is a bit buggy so I use your one instead.
Tim
Tim
Thu Jun 06, 2013 7:25 pm
Ok, if your iSCSI initiator is unsupported legacy and the MS iSCSI is buggy enough to cause a BSOD, what other free iSCSI Initiator do you recommend?
Tim
Fri Jun 07, 2013 12:05 am
There are no other ones to go. You can still use StarWind just don't call for support if there are issues. Pretty much like with MS one.
Tim wrote:Ok, if your iSCSI initiator is unsupported legacy and the MS iSCSI is buggy enough to cause a BSOD, what other free iSCSI Initiator do you recommend?
Tim
