Joakim
Mon Nov 04, 2013 10:11 pm
When I try to Connect to my iSCSI Target I got "Authorization Failed".
Cannot see whats wrong. Any thoughts?
Tue Nov 05, 2013 8:51 am
Could you please provide us with full description of your SAN system and exact steps that you are following before getting this message?
Joakim
Tue Nov 05, 2013 6:16 pm
I have a server running Win 2012 R2 with a HP Tape
Installed Tape Redirect and entered the license.
Followed the guide "Using StarWind Tape Redirector and CA ARCserve Backup" except that I selected "Export tape drive" instead
The iSCSI-target shows up, but I cannot connect.
Mon Nov 11, 2013 11:42 am
Tape Redirector uses different iSCSI port (not 3260) by default. Did you change your initiator settings to match the ones used with target?
Mon Nov 11, 2013 12:18 pm
Have you configured any access rights to target?
Joakim
Mon Nov 11, 2013 8:43 pm
The target is visible so the port are correct (33268)
Authentication Type = Anonymous.
Mon Nov 11, 2013 9:00 pm
Please provide StarWind logs from a failed connect attempt. Thanks!
Joakim wrote:The target is visible so the port are correct (33268)
