C:\Program Files\StarWind Software\StarWind\StarPackConverter.exe E:\Disk1 E:\Disk1 E:\Disk1
Mezzenine wrote:Hi guys,
I already solved my problem, the solution later in this post.
First of all, thank you to Anatoly for his advice. But it didn't work. After, I did this what you wrote in your post I got the message: "The disk has already version 4, nothing to convert".
The solution for this was, I created two new deDup disk, took an Hex Editor an compared all three files for the new disks, so I got all values that has to be the same in each file type. Then I compared my existing disk with one of the new created disk and I saw that the file header of the existing disk was totally different form that I created new. Now I take the Hex-Editor and modified all Values which was different from the file was created new and here we go, it works.
It is my opinion, there is a buck in the conversion tool.
Mezzenine
ajuergens wrote:Thank you...I sent the log to support.
ajuergens wrote:I was wondering if you were able to get any insight on the errors I'm receiving (leads, thoughts, etc.)?
Thank you.
