I am trying to configure HA on the latest release of the beta (20100408), I have read through the Hyper-V and High Availability Storage document and followed the steps to ensure I'm not doing anything wrong/in the wrong order etc.
I get no errors during the creation of the HA Target and the HA Target appears on both StarWind servers after the wizard completes however there is a yellow triangle on each Target and the server log shows :-
4/12 12:53:44.408 448 S: iqn.2008-08.com.starwindsoftware:starwind01-test-ha-01: 65536 session(s) allowed.
4/12 12:53:44.408 448 conf: Target [0x000000000F6B3B60] has been created. Device 'HAImage1' is accesible as target 'iqn.2008-08.com.starwindsoftware:starwind01-test-ha-01'.
4/12 12:53:47.095 448 HA: SscPort_ControlRequest: Event:Received Synchronize command (SynchType = 3)
4/12 12:53:47.095 448 HA: *** SscPort_ControlRequest: Partners is not READY, synchronization failed! (bIsPartnerReady = 0, bIsReadyFromPartner = 0)
Both StarWind servers have 3 networks defined under the network configuration as follows :-
10.1.80.2 -- 3260
192.168.1.89 -- 3260
127.0.0.1 -- 3260
and the management interface is still at the default :-
0.0.0.0 -- 3261
I can ping the servers from each other on both the 10.1 and 192.168 subnets and there is no firewall between the servers (they are VMs hosted on separate Hyper-V servers)
Am I missing something here? I have read through the forum posts where others have had the same issue however the fixes applied to them are not relevant in this case it would seem.
thanks,
Martin
