Hyper-V to VMware, Error opening image, error opening file
Taha
Sun Oct 13, 2024 9:13 am
as title suggests,
whenever i try to convert, it gives me error.
i created the virtual machine manually from the converter, i ticked the windows repair mode.
it gives me the following error:
error opening image
error opening file
then after it shows that the conversion fails
the migration from my laptop hyper-v to remote vcenter.
Sun Oct 13, 2024 10:02 am
Check this viewtopic.php?f=15&t=6763&p=36723&hilit=google#p36723.
P.S. It will be helpful to see the error message.
Taha
Sun Oct 13, 2024 10:43 am
Thanks for your reply, but the thread you link doesnt relate to my issue, or did you mean i should download older version of the converter?
Sun Oct 13, 2024 10:59 am
Thanks for your update. As you did not attach the error you are getting, I tried to guess it from what I previously saw.
Can you please share the error you are getting?
Taha
Sun Oct 13, 2024 11:32 am
the error is on the last screen tab from the V2V converter , it goes as follows:
Started
Creating snapshot...
success
opening image file C:\ProgramData\Microsoft\Windows\Virtualdisk...
Error opening image
Error opening file
Deleting snapshot
success
Conversion failed
Sun Oct 13, 2024 11:35 am
I need logs.
Thanks.
Taha
Sun Oct 13, 2024 1:43 pm
I need logs.
Thanks.
Could you help me extract the logs? i dont see any option on the converter to get logs.
Sun Oct 13, 2024 1:46 pm
Sure.
The logs are under C:\Program Files\StarWind Software\StarWind V2V Converter\logs
Taha
Sun Oct 13, 2024 2:48 pm
find the following
The log file name: 'logs\V2V_Log-20241009-172624.log' (PID 22956)
10/9 17:26:24.260 1c5c Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
10/9 17:26:24.260 1c5c Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.509
10/9 17:26:24.269 1c5c Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
10/9 17:26:24.269 1c5c Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
10/9 17:26:24.277 1c5c Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 22631
10/9 17:26:24.295 1c5c Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 87790000
10/9 17:26:28.471 1c5c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnection
10/9 17:26:30.135 1c5c Facility ???INFO: WrapperHyperV::connect: Host - \\localhost\root\virtualization\v2
10/9 17:26:30.362 1c5c Facility ???INFO: WrapperHyperV::init_version: HyperV version: 10.0.22631
10/9 17:26:30.362 1c5c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
10/9 17:26:34.583 1c5c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
10/9 17:27:30.894 1c5c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
10/9 17:29:58.758 1c5c Facility ???INFO: WrapperESXI::connect: m_url - https://172.16.40.1/sdk
10/9 17:30:01.089 1c5c Facility ???ERROR: WrapperESXI::connect: m_proxy->RetrieveServiceContent fail - 28
10/9 17:30:01.089 1c5c Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault SOAP-ENV:Server [no subcode]
"No connection could be made because the target machine actively refused it.
Detail: connect failed in tcp_connect()
10/9 17:30:01.089 1c5c Facility ???ERROR: VMConverter::ESXIConverter::Connection: connect fail - 28
10/9 17:30:05.582 1c5c Facility ???WARNING: CPPESXConnectionTo::onNext: connect No connection could be made because the target machine actively refused it.
10/9 17:42:43.484 1c5c Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eLocationTo
Sun Oct 13, 2024 3:17 pm
Is it ESXi FREE? There's a connectivity issue with the target host. Check if there are any rules that can be blocking conversion viewtopic.php?t=5739.
