NewGuy
Tue Jun 13, 2023 3:42 pm
I have a server that is hosted by RackSpace with not access to any VM environment etc. I'm trying to move it to Azure. Everything works and I get converting to 72%. Then I get a file read error!. I've checked the logs and this is what I get. Any clues on what I can do? Let me know and thank you in advance.
6/12 3:02:19.291 9bc Facility ???INFO: P2V::getSectorsNext: countClusters - 18276304, dwCountBytes - 18276304
6/12 3:02:54.486 9bc Facility ???WARNING: P2V::getBuffer: ReadFile - 21. The device is not ready.
6/12 3:02:54.486 9bc Facility ???ERROR: CPPConverting::ConvertImage: Read 3
6/12 7:17:19.632 9bc Facility ???ERROR: CPPConverting::Convert: FAILED
Tue Jun 13, 2023 5:11 pm
Conversion from RackSpace is not supported by V2V converter. Please try converting a tiny VHD(x) on that VM to Azure as a test.
NewGuy
Wed Jun 14, 2023 4:52 pm
I'm assuming its a VM I have no access to it excpet RDP. It acts and behaves as a regular server in all other respects. So does it not work on physicals machines? Can I use Starwind P2V to convert the computer to an VHDx image and then upload? Please advise.
